楼主: 384065902
[其他综合] 【福利】编程1:数码管电池容量测试
发表于 2013-11-21 08:50 | 显示全部楼层
谢谢分享!
发表于 2013-11-21 09:18 | 显示全部楼层
谢谢分享,不太明白怎么用
 楼主| 发表于 2013-11-21 14:25 | 显示全部楼层
WOSS1001 发表于 2013-11-20 22:05
LZ是高手!能发个rtx51tny.h吗?我的KEIL没这文件。
RTX51TNY.H
Prototypes for RTX51 Tiny Real-Time Operating System Version 2.02
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __RTX51TNY_H__
#define __RTX51TNY_H__
/* constants for os_wait function */
#define K_SIG      0x01              /* Wait for Signal   */
#define K_TMO      0x02              /* Wait for Timeout  */
#define K_IVL      0x80              /* Wait for Interval */
/* function return values */
#define NOT_OK     0xFF              /* Parameter Error */
#define TMO_EVENT  0x08              /* Timeout Event   */
#define SIG_EVENT  0x04              /* Signal  Event   */
#define RDY_EVENT  0x80              /* Ready   Event   */
extern unsigned char os_create_task     (unsigned char task_id);
extern unsigned char os_delete_task     (unsigned char task_id);
extern unsigned char os_wait            (unsigned char typ,
                                         unsigned char ticks,
                                         unsigned int dummy);
extern unsigned char os_wait1           (unsigned char typ);
extern unsigned char os_wait2           (unsigned char typ,
                                         unsigned char ticks);
extern unsigned char os_send_signal     (unsigned char task_id);
extern unsigned char os_clear_signal    (unsigned char task_id);
extern unsigned char isr_send_signal    (unsigned char task_id);
extern void          os_set_ready       (unsigned char task_id);
extern void          isr_set_ready      (unsigned char task_id);
extern unsigned char os_running_task_id (void);
extern unsigned char os_switch_task     (void);
extern void          os_reset_interval  (unsigned char ticks);
#endif
这是单独rtx51tiny.h
附件是官方例程
rtx51tiny.rar
29.56 KB, 下载次数: 9262, 下载积分: 一乐金币 -1
 楼主| 发表于 2013-11-21 14:28 | 显示全部楼层
cl5828 发表于 2013-11-21 09:18
谢谢分享,不太明白怎么用
直接把数码管骑焊在单片机上加上按键你就会用了,就这么简单
21 22 23 24是控制放电电流的   1脚是实时电压检测
发表于 2013-11-21 17:27 来自手机 | 显示全部楼层
请教下如何改变截止电压,用在低截止电压如3v时如何改。
发表于 2013-11-21 19:50 | 显示全部楼层
谢谢楼主!
发表于 2013-11-21 20:09 | 显示全部楼层
谢谢分享~~~~~~~~~
 楼主| 发表于 2013-11-21 21:05 来自手机 | 显示全部楼层
手机发  回benli  长按p13按键(k3)进入参数设置,长按k2增加到25.4v回0v,在到3v。长按k3闪屏保存
 楼主| 发表于 2013-11-21 21:09 来自手机 | 显示全部楼层
基准电压设置:按住k1 k2 k3上电。松开后显示uref再显示5.0v再显示ad值。请于放电端输入5v电压,长按k3保存
发表于 2013-11-27 15:57 | 显示全部楼层
这个不错,简单易做啊,-5v电压再完善下就好了
GMT+8, 2026-6-23 11:24 , Processed in 0.034299 second(s), 28 queries , Gzip On.
