楼主: yanzeyuan
【DIY新作】LED点阵时钟.3种字体.4种动画.自动旋屏.GPS校时【附原理图】
 楼主| 发表于 2011-7-19 16:29 | 显示全部楼层
对这些部分感兴趣, 能不能发给我学习一下?
3种风格各异的字体;
4种不同的动画切换特效;
红外线 ...
mdy-5153 发表于 2011-7-18 13:53 https://www.yleee.com.cn/images/common/back.gif
其实字体就是相应的字模而已拉,我把字模晒出来:
红外线解码程序我原来共享过YS18荧光管的时钟全套源程序代码,里面有现成的模块,你可以拿来就用,可以找一下我曾经发的帖子。
【3种不同字体的字模】其中除了标准5*7,另外两种是自创的:
code uchar Char1[3][7] ={ { 0x04, 0x06, 0x04, 0x04, 0x04, 0x04, 0x0e },
        { 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c, 0x0c },
        { 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08 }}; // 1
code uchar Char2[3][7] ={ { 0x0e, 0x11, 0x10, 0x08, 0x04, 0x02, 0x1f },
        { 0x1e, 0x18, 0x18, 0x1f, 0x03, 0x03, 0x1f },
        { 0x1e, 0x10, 0x10, 0x1e, 0x02, 0x02, 0x1e }}; // 2
code uchar Char3[3][7] ={ { 0x1f, 0x08, 0x04, 0x08, 0x10, 0x11, 0x0e },
        { 0x1f, 0x18, 0x18, 0x1e, 0x18, 0x18, 0x1f },
        { 0x1e, 0x10, 0x10, 0x1e, 0x10, 0x10, 0x1e }}; // 3
code uchar Char4[3][7] ={ { 0x08, 0x0c, 0x0a, 0x09, 0x1f, 0x08, 0x08 },
        { 0x1b, 0x1b, 0x1b, 0x1f, 0x18, 0x18, 0x18 },
        { 0x12, 0x12, 0x12, 0x1e, 0x10, 0x10, 0x10 }}; // 4
code uchar Char5[3][7] ={ { 0x1f, 0x01, 0x0f, 0x10, 0x10, 0x11, 0x0e },
        { 0x0f, 0x03, 0x03, 0x1f, 0x18, 0x18, 0x1f },
        { 0x1e, 0x02, 0x02, 0x1e, 0x10, 0x10, 0x1e },}; // 5
code uchar Char6[3][7] ={ { 0x0c, 0x02, 0x01, 0x0f, 0x11, 0x11, 0x0e },
        { 0x0f, 0x03, 0x03, 0x1f, 0x1b, 0x1b, 0x1f },
        { 0x1e, 0x02, 0x02, 0x1e, 0x12, 0x12, 0x1e },}; // 6
code uchar Char7[3][7] ={ { 0x1f, 0x10, 0x08, 0x04, 0x02, 0x02, 0x02 },
        { 0x1f, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18 },
        { 0x1e, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10 },}; // 7
code uchar Char8[3][7] ={ { 0x0e, 0x11, 0x11, 0x0e, 0x11, 0x11, 0x0e },
        { 0x1f, 0x1b, 0x1b, 0x1f, 0x1b, 0x1b, 0x1f },
        { 0x1e, 0x12, 0x12, 0x1e, 0x12, 0x12, 0x1e },}; // 8
code uchar Char9[3][7] ={ { 0x0e, 0x11, 0x11, 0x1e, 0x10, 0x08, 0x06 },
        { 0x1f, 0x1b, 0x1b, 0x1f, 0x18, 0x18, 0x1e },
        { 0x1e, 0x12, 0x12, 0x1e, 0x10, 0x10, 0x1e },}; // 9
code uchar Char0[3][7] ={ { 0x0e, 0x11, 0x19, 0x15, 0x13, 0x11, 0x0e },
        { 0x1f, 0x1b, 0x1b, 0x1b, 0x1b, 0x1b, 0x1f },
        { 0x1e, 0x12, 0x12, 0x12, 0x12, 0x12, 0x1e },}; // 0
 楼主| 发表于 2011-7-19 16:30 | 显示全部楼层
在房子里面也能收到GPS信号吗?请问用的是什么模块
sup999 发表于 2011-7-18 14:47 https://www.yleee.com.cn/images/common/back.gif
房子里面收不到GPS信号的。录像的时候是在客厅,GPS模块扔到了阳台。
用得就是我图上的模块,台湾产,环天!
动态效果实在是太漂亮了
cykhyk 发表于 2011-7-18 18:10 https://www.yleee.com.cn/images/common/back.gif
呵呵,过奖啦
 楼主| 发表于 2011-7-19 16:31 | 显示全部楼层
看LZ的电路板设计非常好看, 应该不是手工布线的吧, 用的什么自动布线工具? 还是AD中的什么功能?
mdy-5153 发表于 2011-7-19 06:11 https://www.yleee.com.cn/images/common/back.gif
我几乎不用AD的自动布线,每一条线都是手工布的。
自动布线需要创建很多规则,才能布的好。
有那时间,这么百十个元器件手工布就布完啦。
其实AD很好用....
 楼主| 发表于 2011-7-19 16:32 | 显示全部楼层
GPS校时我也很感兴趣,虽然一般GPS在没有信号的情况下也能正确走时,但坚持的时间太短了。
hicool 发表于 2011-7-19 13:40 https://www.yleee.com.cn/images/common/back.gif
是的,GPS在没有信号的时候,也能输出时间、
但是这个时间是上次连线卫星更新以后的时间,只是没有连接卫星的时候GPS模块内部也有RTC,能维持时钟走时,但是这个精度就靠GPS内部的RTC了,时间长了也会不准。
发表于 2011-7-19 16:39 | 显示全部楼层
赞,非常精美!
发表于 2011-7-20 18:29 | 显示全部楼层
艺术品,膜拜
发表于 2011-7-21 16:39 | 显示全部楼层
动画是怎样实现的? 亚克力板外壳一直想做, 也是找不到好的切割方法, 没雕刻机。 要不就实验用雕刻机切割了。
发表于 2011-7-21 21:46 | 显示全部楼层
 楼主| 发表于 2011-7-22 00:01 | 显示全部楼层
动画是怎样实现的? 亚克力板外壳一直想做, 也是找不到好的切割方法, 没雕刻机。 要不就实验用雕刻机切割 ...
mdy-5153 发表于 2011-7-21 16:39 https://www.yleee.com.cn/images/common/back.gif
动画是一帧帧的用算法处理的。
比如翻页,就写一个函数,不停的返回当前帧的字模数组指针........
亚克力还是要用激光切割的好,可以找当地做亚克力加工的,广州反正有很多。
GMT+8, 2026-5-29 23:11 , Processed in 0.036916 second(s), 26 queries , Gzip On.
