EMERSON艾默生INV-4810E NetSure301iC21正弦波嵌入式逆变器
全新备件19寸机架NetSure301iC21,内装2只INV-4810E逆变模块,输入DC48V,输出AC220V,功率2000VA。
外形尺寸;宽483x深340x高86毫米,重量约11.3公斤。
逆变器支持并机扩容,可以多台逆变器N+1冗余并联使用。
淘宝店客服
淘宝店客服2
骚扰电话多,请加微信注明来意,手机13927433520 QQ 841526919 一乐电子淘宝店 https://shop33648706.taobao.com/
淘宝购买链接
Inverter Solution is an
integrated inverter power
system designed for
applications where a very high
reliability AC supply is required.
The Matrix modular design
ensures maximum flexibility to
configure solutions to
customers’ requirements.
Modules include inverters,
Static Transfer Switch,
controller, interface module and
Maintenance Bypass Module.
With its versatile “building
block” design and n+x
redundant configuration, the
Matrix ensures reliable
telecommunication and
industrial AC power.
The Matrix Static Transfer
Switch provides automatic and
instantaneous load transfer
between mains power and
inverter power and back again,
to ensure uninterrupted AC
supply to sensitive electronic
equipment.
The Matrix solution uses digital
microprocessor control. The
monitoring controller gives realtime
system status through
comprehensive LCD /LED
displays, and allows program
settings through the display
panel.
With the Matrix communication
interface module installed, you
can control and monitor the
system remotely.
