MWR-SH10N Air Conditioner Wired Wall Remote Controller
购买链接 https://item.taobao.com/item.htm?id=601464839733
重量0.75公斤
Features
• Internal temperature sensor • Backlight
• Built-in infrared receiver to allow control of indoor unit wirelessly with MR-DH00U or MR-EH00U wireless controllers
• Indoor unit operation ON/OFF, operation mode, set temperature, louver position (cassette, ceiling, wall units), and fan speed settings
• Error display
• Filter replacement alARM display and reset
• Single indoor unit control or multiple unit control (maximum 16 units)
• All button lock (option)
• Partial controller button lock (ON/OFF, temperature setting, fan speed, timer function, louver swing, sleep function, quiet function, outing function, and operation mode buttons)
• Upper and lower temperature setting restriction
• Heat, cool, dry, fan, and auto mode skip options (skips specified mode on wired controller)
• Restrict wireless controller signal (optional)
• Single event timer function (ON/OFF control, 30 minutes 24 hours timer setting options)
• System/indoor unit function and operation indication (defrost, error, restricted controller, central control, and SPi status)
• Quiet Mode setting (for supported units)
• Service mode for connected indoor unit operation monitoring, addressing, and setup
• Can be used to specify “Mode Master” while connected to a single indoor unit when used with heat pump systems to control system mode (heating or cooling)
• Outing function to keep a minimum heating (61~72°F) and cooling (77~86°F) temperature while you are away. When Outing mode is
activated, the unit will operate at the specified Outing temperature. If indoor temperature is 9°F difference from desired Outing temperature, the indoor unit will turn on. If indoor temperature is the same as desired Outing temperature, the indoor unit will turn off automatically. This is repeated depending on indoor temperature for 12 hours. After 12 hours, Outing mode is released/canceLED.
2018-10-11 17-55-57.jpg (246.46 KB, 下载次数: 0)
2018-10-11 17-54-35.jpg (330.91 KB, 下载次数: 0)
2018-10-11 17-54-08.jpg (296.79 KB, 下载次数: 0)
2018-10-11 17-53-33.jpg (245.99 KB, 下载次数: 0)
