恒流LED驱动器ESS030W-0700-32
LED调光驱动器ESS030W-0700-32输出电流700ma电压21–32V
规格
| 类型 | 恒定电流 |
| 拓扑 | AC DC 转换器 |
| 输出数 | 1 |
| 电压 – 输入(最小值) | 120VAC |
| 电压 – 输入(最大值) | 277VAC |
| 电压 – 输出 | 21 ~ 32V |
| 电流 – 输出(最大值) | 700mA |
| 功率(W) | 29W |
| 调光 | 模拟,ELV,双向可控硅 |
| 特性 | OCP,OTP,SCP |
| 等级 | IP20 |
| 工作温度 | – |
| 效率 | 90% |
| 端子类型 | 导线引线 |
| 大小/尺寸 | 3.93″ 长 x 1.02″ 宽 x 0.93″ 高(99.8mm x 26.00mm x 23.7mm) |
CONSTANT CURRENT LED DRIVERS
ESS/ESST SERIES
6-40 W, TRI-MODE DIMMING™ (0-10 V & TRIAC/ELV)
FEATURES:
- Compatible with TRIAC (forward-phase or leading-edge), ELV (reverse-phase or trailing-edge) and 0-10 V dimmers
- ESSxxxW models: TRIAC and ELV dimming only at 120 Vac
- ESSxxxE models: ELV dimming only at 230 Vac
- 90°C maximum case hot spot temperature
VIEW ALL FEATURES
厂家资料
http://www.erppowerllc.com/en/products/constant_current_led_drivers/ess-series
LED调光驱动器,型号ESS030W-0700-32输出电流700ma电压21–32V
尺寸84 x 40 x 25.2 mm,重量110克,0-10V是调光信号,不是驱动输出。
无标签版本,但型号是正确的。
Features
- Compatible with TRIAC (forward-phase or leading-edge) / ELV (reverse-phase or trailing-edge) and 0-10 V dimmers
- TRIAC dimming only at 120 Vac
- Linear 0-10V dimming transfer function: 10V=100%, 1V=10%, 0.1V=1%
- Lifetime: 109,000 hours at 70°C case hot spot temperature (57°C ambient temperature) for ESS030W-0620-42 (26 W)
- Protections: output open load, over-current and short-circuit (hiccup), and over-temperature with auto recovery
- Conducted and radiated EMI: Compliant with FCC CFR Title 47 Part 15 Class B (120 Vac)/Class A (277 Vac) and EN55015 (CISPR 15) at 220/230/240 Vac
- Complies with ENERGY STAR® luminaire specification and DLC (DesignLight Consortium®) technical requirements
- IP64-rated case with silicone-based potting
- Class 2 power supply
- Double-insulated power supply between input and output (class II)
ESST040E-0900-42
ESS015W-0300-42
ESST040W-1400-27
ESST040W-1400-24
ESST040W-0900-42
ESST040W-0800-42
ESS030W-1750-14-Z1
ESS030W-1050-21
ESS030W-0700-42-Z1
ESS030W-0700-32
ESS030W-0550-42-Y1
ESS030W-0500-42-Z1
ESS020W-1400-14-Z1
ESS020W-0500-34
ESS015W-1050-14-Z1
ESS015W-1000-12
ESS015W-0700-18-Z1
ESS015W-0350-42-Z1
ESS010W-0500-18
ESS010W-0250-42-Z1
ESS010W-0180-42
ESS020W-0450-42
ESS020W-0500-32
ESS020W-0700-24
ESS030W-0500-42
ESS030W-0550-42
ESS030W-0620-42
ESS030W-0700-42
ESS030W-0900-27
ESS030W-1100-27
ESS020W-1400-14
ESS030W-0900-32
ESS030W-1750-14
ESS030E-0500-42
ESS030E-0700-42
ESS010W-0250-42
ESS015W-0350-32
ESS015W-0350-42
ESS015W-0440-34
ESS015W-0440-25
ESS020W-0350-56
ESS020W-0400-42
ESS010W-0200-42
ESS010W-0350-24
ESS010W-0500-12
ESS010W-0750-12
ESS015W-0700-18
ESS015W-1050-14
ESS010E-0250-42
ESS015E-0350-42
