ERP Power, LLC ESS030W-0700-32
无标签版本,但型号是正确的。
Features
- Compatible with TRIAC (forward-phase or leading-edge) / ELV (reverse-phase or trailing-edge) and 0-10 V dimmers
- TRIAC dimming only at 120 Vac
- Linear 0-10V dimming transfer function: 10V=100%, 1V=10%, 0.1V=1%
- Lifetime: 109,000 hours at 70°C case hot spot temperature (57°C ambient temperature) for ESS030W-0620-42 (26 W)
- Protections: output open load, over-current and short-circuit (hiccup), and over-temperature with auto recovery
- Conducted and radiated EMI: Compliant with FCC CFR Title 47 Part 15 Class B (120 Vac)/Class A (277 Vac) and EN55015 (CISPR 15) at 220/230/240 Vac
- Complies with ENERGY STAR® luminaire specification and DLC (DesignLight Consortium®) technical requirements
- IP64-rated case with silicone-based potting
- 90°C maximum case hot spot temperature
- Class 2 power supply
- Double-insulated power supply between input and output (class II)
Product Attributes
| TYPE | DESCRIPTION | SELECT |
| Category | Power Supplies – External/Internal (Off-Board)LED Drivers | |
| Mfr | ERP Power, LLC | |
| Series | ESS (30W) | |
| Package | Box | |
| Product Status | Active | |
| Type | Constant Current | |
| Topology | AC DC Converter | |
| Number of Outputs | 1 | |
| Voltage – Input (Min) | 120VAC | |
| Voltage – Input (Max) | 277VAC | |
| Voltage – Output | 21 ~ 32V | |
| Current – Output (Max) | 700mA | |
| Power (Watts) | 22 W | |
| Dimming | Analog, ELV, Triac | |
| Features | OCP, OTP, SCP | |
| Ratings | IP64 | |
| Operating Temperature | – | |
| Efficiency | 87% | |
| Termination Style | Wire Leads | |
| Size / Dimension | 3.30″ L x 1.57″ W x 0.99″ H (83.8mm x 39.9mm x 25.1mm) | |
| Approval Agency | cRUcs, SA, ENEC, FC, CE, CCC, CB, KC, NEMKO, UL, CSA | |
| Mounting Type | Chassis Mount | |
| Weight | – | |
| Base Product Number | ESS030W |
Report an ErrorView Similar
