乌克兰网友DIY的M8V7数字电源
DIY作品秀 •
作者: kirich
| If anyone is interested, here is my version of the implementation of the instrument. Current up to 15 Amps (can somebody share firmware of up to 30 amps). Maximum power of 400 watts. |
99IMG_5830 копия.jpg (425.76 KB, 下载次数: 2)
75IMG_5728 копия.jpg (498.25 KB, 下载次数: 2)
78IMG_5738 копия.jpg (332.1 KB, 下载次数: 4)
76IMG_5730 копия.jpg (584 KB, 下载次数: 3)
102IMG_5843 копия.jpg (394.33 KB, 下载次数: 4)
97IMG_5814 копия.jpg (437.29 KB, 下载次数: 2)
96IMG_5813 копия.jpg (423.29 KB, 下载次数: 4)
95IMG_5810 копия.jpg (386.55 KB, 下载次数: 1)
130IMG_5941 копия.jpg (464.09 KB, 下载次数: 4)
131IMG_5945 копия.jpg (343.81 KB, 下载次数: 1)
134IMG_5955 копия.jpg (495.77 KB, 下载次数: 4)
135IMG_5956 копия.jpg (531.09 KB, 下载次数: 2)
| I’ll try to explain once again. No problems getting the output current of 15 amperes. If I add two gain stage current, the current will be 15 amperes. But when you install the current, the indicator will be displayed only 0-5Amper. When you change the current in the range of 5-15 amps, the processor does not change the output, since the PWM output PWM is already 100%. The problem occurs when you set up the necessary current. Set current PWM (PWMA) Voltage op amp comparison On display On pin PB1 MCU Pin 3 U51A (LM358) 0.000As 0% 0 V 1.000As 20% 0.05 V 2.000As 40% 0.10 V 3.000As 60% 0.15 V 4.000As 80% 0.20 V 5.000As 100% 0.25 V 6.000As 100% 0.25 V 15.000As 100% 0.25 V Even if I add the gain of the current (as in the diagram above), then I get 15 Amps current. But I have to display the current will be less than 3 times, because the change occurs only in the range of adjustment 0-5Amper all. Adjusting the PWM and the input voltage of the operational amplifier should look like – Set current PWM (PWMA) Voltage op amp comparison On display On pin PB1 MCU Pin 3 U51A (LM358) 0.000As 0% 0 V 3.000As 20% 0.05 V 6.000As 40% 0.10 V 9.000As 60% 0.15 V 12.000As 80% 0.20 V 15.000As 100% 0.25 V Then the adjustment range is fully used. ,, In a range of settings (no measurement) 5-15 Ampere current MCU does not change anything on pin PWMA (PB1). If the adjustment range was up to 30 amps, it would look like this – Set current PWM (PWMA) Voltage op amp comparison On display On pin PB1 MCU Pin 3 U51A (LM358) 0.000As 0% 0 V 6.000As 20% 0.05 V 12.000As 40% 0.10 V 18.000As 60% 0.15 V 24.000As 80% 0.20 V 30.000As 100% 0.25 V The voltage at the pin 3 of the operational amplifier is used to compare the voltage at the current measuring resistor. If I add additional transistors as the scheme, I have a 3-fold increase in the output current, but it will be three times larger than the set. When installing additional transistors will be so – Set current output current on display really 1.000As 3.000 Amp 2.000As 6.000 Amp 3.000As 9.000 Amp 4.000As 12.000 Amp 5.000As 15.000 Amp 6.000As 15.000 Amp 15.000As 15.000 Amp |
